quote:Originally posted by DellisI know this has been discussed before on the forum, I'm chasing the specs on the odeesy type battery or similar, that is suited to starting a EA 81, prerotating 29 foot blades and keeping all the electrical things running. Being situated in Gove , where can I by one? Dave EllisG'day Dave,Doesn't matter what sort of lead/acid battery you put in your gyro (or anything else for that matter), the level of discharge, the rate of the charge, and the level to which you recharge will all have a very large impact on the life of the battery. Life of batteries is often quoted in "cycles" (cycles being the number of times the battery will deliver its rated storage capacity in its lifetime.) Say for instance, your particular battery has a storage capacity of 10 amp hours. If its "life" is a 1000 cycles under certain discharge regime, then it is capable of delivering 1000 x 10 = 10,000 ah in its life time. Generally to get the 1000 cycles, you shouldn't discharge the battery more than 10%. If you were to discharge the battery to 30% regularly, then the life of the battery could easily drop to 300 cycles. If you regularly draw 50% of the storage, then the life could be well under 100 cycles.Forget the quantum of the figures above. For some batteries they will be correct, for others not. That is not important. What is important is that:
WILL have an enormous impact on the life of the battery. If you are having trouble with battery life, make sure you address these issues for maximum life.RegardsFredBairnsdale
- the level to which you discharge your batteries
- the rate at which you recharge your batteries; and
- the level to which you recharge your batteries
