Dropped a cylinder in my EJ25 recently and finally traced the most likely cause to injectors. Changed plugs, checked compression and lead resistances, all good.
Pulled the injectors, had them tested and sure enough, one was bad. No problem thought I, just nip on over to Sun Spares and get new ones. Hah! Turns out that the engine is a JAP import and the injectors in it are not the same as the Oz ones. I chased all over Oz with no luck. Even had performance people check their exotic contacts with no luck.
Enter Mr. Google. Reconditioned ones available ex USA at around US$50 each, but no full sets. One here and one there. And, US$150 in freight charges each. So, took a punt and ordered a new set from China. At around $80, I thought that if they were no good, then the cost wouldn't break the bank.
They arrived is very quick time, less than 3 weeks. I took them to the injector guy who checked them out. Two were crook, but came up to spec after ultrasonic cleaning and whatever else they do. Fitted them yesterday and did a full power ground run with good results. No missing and smooth. Mixtures are a little richer than before which is to be expected. Test fly tomorrow at a couple of grand over the strip just in case.
The moral of the story is to have any new injectors, especially from China, checked out before trusting them in our gyros.
Compliments of the Season to one and All.
