Well got round to testing gauge set up on 582 rotax last week it had an ivo prop & pulled 6100rpm with 1100 egt's no breaking down but EGO gauge showed more to lean side [was flickering 110deg out of 270deg]so I adjusted mixture by lifting needle one clip position ran it up again got 7000rpm and egt's @ 1000this may have saved a costly blow up Butch
EGO gauge on 2strokes
G'Day Butch,Not sure I understand fully. If you are getting 7000rpm static dont you run the risk of pulling high top end rpms when in the air??Cheers,Mitch.www.thebutterflyllc.com
Great Butch, sounds like a helpful piece of gear. I don't quite understand an increase of 900 rpm with just lifting the needles one notch. The needles have very little, if any effect, at wide open throttle on those carbs. I thought that the needles were for the mid range, and the main jet was for max throttle.What am I missing here?Aussie Paul. []www.firebirdgyros.com
First Greg on this gyro the ivo prop was bent forwards & a bit soft[stuffed]Paul the needle is still located in the resepter at full throttle so lifting it will allow more fuel through the correct fix is to now enlarge main jet and re lower needle thanks for your interest Butch
quote:Originally posted by Butch S.First Greg on this gyro the ivo prop was bent forwards & a bit soft[stuffed]Paul the needle is still located in the resepter at full throttle so lifting it will allow more fuel through the correct fix is to now enlarge main jet and re lower needle thanks for your interest ButchOk Butch, understood, BUT I fail to see how an increase of 900 engine rpm would be possible. I have never experienced that amount of rpm increase, with one needle slot changed, in a couple of thousand 2 stroke hours.Bugger, I thought I knew everything!!!!![^] Obviously not!!![]Cheers.Aussie paul.[
