Breather on Rotax PRSU
  • Breather on Rotax PRSU
    Many thanks to all who made the trip to Lameroo and provided me with many future construction ideas.I travelled in the C172 parked at the end of the line so forgive my sins for not having G2244 present.My question here is that I noticed some Subaru powered aircraft with breather tube extensions on their rotax PRSUs and I think one was even connected to the PCV system. Is this because these gearboxes are prone to spitting out gear oil as I have not noticed this on mine despite relatively low hours in service.Or is it perhaps that these particular gearboxes are overfilled creating this anomaly and if so, has it been a problem noted elswhere that they need extra oil to counteract adverse wear or other difficulties?Just an observation that I am sure will have a logical explanation.Mike
    No experts available or is this something that is too obvious to comment on ?
      AirboatsNo experts about, I expect. :-Cheers,Mitch.
        Guys,In my experience there is no requirement for tubes unless you over fill or use a heavier grade of oil.Adrian
          Ta,Given I saw at least 3 machines at the Nationals with breathers, you either do not agree with Adrian or have done what he suggested in either overfilling or using a heavier grade.Why is this so? Does the PRSU work better, last longer, require less maintenance, run quieter etc?Is there a rationale for your mods that has not been explained here?Please explain.(I think that"s a Qld colloqialism)Mike
            Ta,Given I saw at least 3 machines at the Nationals with breathers, you either do not agree with Adrian or have done what he suggested in either overfilling or using a heavier grade.Why is this so? Does the PRSU work better, last longer, require less maintenance, run quieter etc?Is there a rationale for your mods that has not been explained here?Please explain.(I think that"s a Qld colloqialism)MikeMike I have always run 2 stroke Rotax engines, and have always used the correct oil grades.With over 300 hours now I have never once had to modify my breather in any way!!!!Sam.
              Hi All, In the Rotax book of destructions for the 503 fitted with a 2.58 : 1 reduction box the ill. no. 34 part no. 974 532 vent line 70 mm qty = 1. So there you have it from the manufacturers spare parts list. Hop that clears things up for yuz,
                Des,Just a point of clafication on my post there is a requirement for a breather ala Rotax but the addition of additional tubes etc for a rotax box is unnecessary.This comment is for Rotax C & E box"s only.
