Many thanks to all who made the trip to Lameroo and provided me with many future construction ideas.I travelled in the C172 parked at the end of the line so forgive my sins for not having G2244 present.My question here is that I noticed some Subaru powered aircraft with breather tube extensions on their rotax PRSUs and I think one was even connected to the PCV system. Is this because these gearboxes are prone to spitting out gear oil as I have not noticed this on mine despite relatively low hours in service.Or is it perhaps that these particular gearboxes are overfilled creating this anomaly and if so, has it been a problem noted elswhere that they need extra oil to counteract adverse wear or other difficulties?Just an observation that I am sure will have a logical explanation.Mike
Breather on Rotax PRSU
Ta,Given I saw at least 3 machines at the Nationals with breathers, you either do not agree with Adrian or have done what he suggested in either overfilling or using a heavier grade.Why is this so? Does the PRSU work better, last longer, require less maintenance, run quieter etc?Is there a rationale for your mods that has not been explained here?Please explain.(I think that"s a Qld colloqialism)Mike
Ta,Given I saw at least 3 machines at the Nationals with breathers, you either do not agree with Adrian or have done what he suggested in either overfilling or using a heavier grade.Why is this so? Does the PRSU work better, last longer, require less maintenance, run quieter etc?Is there a rationale for your mods that has not been explained here?Please explain.(I think that"s a Qld colloqialism)MikeMike I have always run 2 stroke Rotax engines, and have always used the correct oil grades.With over 300 hours now I have never once had to modify my breather in any way!!!!Sam.
