Hey Murray, I believe that Victoria is still part of Oz!!![] LOL,and yes, I think that they would be a "SUPER DOOPER" option for Firebird.[]I will have to test them stick fixed first though!!!![^]Testing may be delayed until the lakes fill up around here.Using a coloured gps I have been landing on water!!![:0] 'sure makes a hellova change from walking on it though!!!!![^]Go to bed Bruty. Ok, ok, ok.[!][V][!][V]Aussie Paul.[]www.firebirdgyros.com
Murry, you're on to something here....Build a slotted rudder with a travelling HS. By using an actuator here to raise or lower the wings according to the need. Ted ( Designs that should have been kept secret Inc)
Woz thinkn the pelican had a win, coz the thread went dead.Ignorance is bliss............but only till you realise you were.Ingratitude stinks.......be generous carefully.
I sure would like to see those floats up here under a Little Wing.Be just the thing for scootin around the Whitsunday Islands, whalewatching and doin stuff.I wouldn't bother trying to raise or lower the floats. Just hang thema couple of inches below the floats to run on the hard.When up on the plain the front wheel is outa the water.This is how some of the FW ultralight thingies are set up.Little Wing with a 914 turbo, please.Cheers.Robert DunnMackay. Qld.Growing old is good while it lasts.
