for sale
  • for sale
    I have for sale, a EA 82, factory fitted turbo , fuel injected engine. It comes with a belt drive system, new cam belts, water pump and a new gates toothed drive belt. I have gone for horse power, and gearbox to drive my 2 place machine, asking
    What is the difference between the EA81 and EA82. Also what horsepower
      EA81 is a push rod O.H.V. motor the EA82 is single O.H.C.motor
        The EA82, subaru engine, pronounced " su bar u", has normally about 87 hp, while the 82 turbo, with 7 lbs boost, using avgas, will produce about 127 hp. This will run quite merrilly all day, bump the boost up to 13 lbs, and the engine will probally
          Guys,Remember the important thing is power to weight and not just horsepower.The EA82 weighs significantly more but I agree in turbo form its still pretty good.I used to run a EA81 Turbo with boost limited to 8 PSI at 5100rpm and 5PSI 4200 to 5000. The power to weight is great 125hp for 105kg. The engine has 600+hrs and still going strong.Adrian
            Guys,Remember the important thing is power to weight and not just horsepower.The EA82 weighs significantly more but I agree in turbo form its still pretty good.I used to run a EA81 Turbo with boost limited to 8 PSI at 5100rpm and 5PSI 4200 to 5000. The power to weight is great 125hp for 105kg. The engine has 600+hrs and still going strong.Adrian Hi Adrian & Darrell1) What was your max RPM on Climb out? was it 5100.2) What is your cruise RPM and fuel burn.Regards SamL.......
              Thanks for the info about the EA81. I actually have another EA81 sitting in my shed with a turbo on it and I keep thinking about it. My engine is brand new and was built with low compression to give good reliability. Don"t want to ruin it by putting a turbo on but would love a few extra horsepower.
                Sam,Max RPM 5100Cruise RPM depends on Temp and how fast I wanted to go -50kts 420055kts 4600Fuel burn 14 to 18l per hour depending on winds ( not FI, I ran a "blow through" carbi much lighter!)Compression ratio 7:1 and keep the average boost below 5psi otherwise it will be a short life eng!Adrian
                  Sam,Max RPM 5100Cruise RPM depends on Temp and how fast I wanted to go -50kts 420055kts 4600Fuel burn 14 to 18l per hour depending on winds ( not FI, I ran a "blow through" carbi much lighter!)Compression ratio 7:1 and keep the average boost below 5psi otherwise it will be a short life eng!Adrian Gees thats not bad at all, I expected a higher consumption. The RPM is very typical of Subaru engines, isnt it. You cant complain about your motor Adrian, given its 600 hours old and still going. Thanks Regards SamL.........
                    adrian, so that is for a 2 seater right ?
                      Tony,No thats on G198 a single seat gyro. Remember Iam 120kg!Adrian
                        adrian, i"m not far behind you but taller. it"s important to look at the big picture. what else is the build prop and rotors etc of yours? so for 2g is that a spare in the making????? for big blokes like us that is ?or is the
                          the EA82 turbo, injected engine, that I had listed as for sale, I have
