Hi there,What type of electric fuel pump should I be looking at?loafar.
Electric Fuel Pumps
Loafar,I recently fitted this one to a EA81 with Turbo. http://www.eziautoparts.com.au/elect...p-40106.htmlAs a minimum the fuel pump needs to meet the statement below.(b) Pump systems: the fuel flow rate for each pump system (main andreserve supply) must be at least 125% of the actual take-off fuelconsumption of the engine at the maximum power established fortake-off.Note:-Fuel flow is measured after the float valve(s) in carburettor enginesand at the inlet to the injectors in injected engines.Rob
