Electric Fuel Pumps
  • Electric Fuel Pumps
    Hi there,What type of electric fuel pump should I be looking at?loafar.
    What sort of engine?
      Ea 81 Subie with turbo.
        Loafar,I recently fitted this one to a EA81 with Turbo. http://www.eziautoparts.com.au/elect...p-40106.htmlAs a minimum the fuel pump needs to meet the statement below.(b) Pump systems: the fuel flow rate for each pump system (main andreserve supply) must be at least 125% of the actual take-off fuelconsumption of the engine at the maximum power established fortake-off.Note:-Fuel flow is measured after the float valve(s) in carburettor enginesand at the inlet to the injectors in injected engines.Rob
          Thanks Rob,Matter of interest, the same pump on Ebay is $35.00 with free postage.cheer"s loafar.
            Yep thats one of the pumps that appears to used on Carb based engines a lot.The only reason I asked was if it was a fuel injected engine, then something like a Bosch fuel injection pump would have been one good choice.
              Thanks.loafar
