Was wondering what sized rotors all those 912 single place /pod gyro drivers are using? & how much[ if you know] pitch in the hub bar.I reckon 27"s should be about right but with minium pitch [ .8*] 2 degrees pitch might be too much and slow the rotors down to mayby less than 300 revs. The 26 fter"s I"m running rev around 360 revs & I need 400 revs to keep the ship happy.
Rotor Size for 912 powered gyros
Chopper what is your typicacal Auw mustering?from what you have said it sounds like you need bigger blades. I like to see 325 to 350rrpm with my auw I need 27.5 to 28" . Swap over the blades from the old subi machine that should do the trick.Adrian
Max all up weight would be about 420Kg I think.I put my 27 fter"s on and they have too much bite, revs down to 285. Need to see if I can get another hub bar with .8 of a degree I reckon. Engine revs dropped off the dial, half full fuel & 3200 was plenty but airspeed was lost as well.
Chopper,Looks like 27" blades set at around about 1 deg pitch (AK or Pat) would be ideal. I am a little confused with your stated eng revs as the 912 is happiest at 4800 to 5300 especialy at 400+kg. You need to make sure the prop is not over pitched. I set mine at what ever pitch is needed to allow a static test for WOT (Wide open throttle) at 5800rpm. One of the things you will need to get used to is the 912 likes the revs and is a bit louder than what your subi probably is. Just my 10c worth,Adrian
