A warning for those buying new AK rotors or new hub bars. Seems one hub bar has turned up with a plate between the pillar block & the hub bar. Totally unacceptable.
Also check once fitted rotors fitted to gyro that you have the full amount of teeter clearance because one set of AK's did NOT have the required clearance, fortunately the pilot had enough experience to recover from the hammering that came through the stick when he tried his first turn.
into a howling headwind ( 40 Kilometers per hour) ground speed ) and rough as guts to boot, however I was flying the Rosco ! Had I been in the Green machine, it would at least been a nice smooth ride
