Paul flying in these wonderful machines is hard to resist.
You may wish to discuss with Chum about his vertical stabiliser design. Am I correct in assuming that if he loses one of his rudder cable connections that the incoming airflow will force the rudder hard over to the side which was last in the airflow causing the aircraft to spiral or are there enough "tail feathers" forward of the pivot point still available to keep it straight and not flutter?
Regards...........Chook.
