Oh So Good!!
  • Oh So Good!!
    As some of you will be aware, I bought a new [ secondhand ] grader back a while ago.....that had the odd thing that needed fixing !! Well, I have done a couple of days grading, today I did a full days grading and its a real pleasure to get out and not look like a gollywog & have to take your clothes off outside the house and give them a really good shake for 10 minutes beore you brought them in, then stand in the shower & fill the drain with dirt.The lungs / eyes etc are appreciating the change as well!
    Good to hear your updates Brian. What I need up here is some machine that can knock out an airstrip in the night that can be blamed on aliens.
      Non reflective alien cousins Max. Regards......Chook.
        Thanks for the idea Chook, should only cost a few cartons. The big problem is finding enough sober alien cousins at the same time. They get about three times the pension I get, and I paid tax for 50 years!
          Max I retire in December which means that the 5 no hopers that have been living off my tax now have to go out and get a job.
            OK! Now that you have the grader really flying are you going to take it to the ASRA Nationals? There is probably a cult following developing for it after all work you have done on it.What size rotor and prop does it have?
                Good to hear your updates Brian. What I need up here is some machine that can knock out an airstrip in the night that can be blamed on aliens.You arent allowed to make an airstrip Max ? Difernt to down here, airstrips are one thing there are no rules on, I can have as many, wherever I choose as long and wide as I choose. There are a couple going to go in when I get a dozer in the vicinity, which should be later this year ;D
                  Arr, Chook, you must be an old bugger like me. Flying gyro"s is a great way to spend retirement. I need something a bit more upmarket than a grader Brian. Maybe the biggest one of those seven flying disks in a hanger at area 51 which we"re not supposed to know about and if you talk about them 45 percent of the population will think you"re a nutter. It would leave no wheel marks!
                    Arr, Chook, you must be an old bugger like me. Flying gyro"s is a great way to spend retirement. I need something a bit more upmarket than a grader Brian. Maybe the biggest one of those seven flying disks in a hanger at area 51 which we"re not supposed to know about and if you talk about them 45 percent of the population will think you"re a nutter. It would leave no wheel marks!I must be part of that 45%.Graeme.
                      Funny that, Graham, if you believe in ETs 45% of the population including the Gov. think you"re a nutter, and if you believe that a God turned himself into a man and came to earth, huge Gov. backed institutional monolithical orginisations will pat you on the back!
