As some of you will be aware, I bought a new [ secondhand ] grader back a while ago.....that had the odd thing that needed fixing !! Well, I have done a couple of days grading, today I did a full days grading and its a real pleasure to get out and not look like a gollywog & have to take your clothes off outside the house and give them a really good shake for 10 minutes beore you brought them in, then stand in the shower & fill the drain with dirt.The lungs / eyes etc are appreciating the change as well!
Oh So Good!!
Good to hear your updates Brian. What I need up here is some machine that can knock out an airstrip in the night that can be blamed on aliens.You arent allowed to make an airstrip Max ? Difernt to down here, airstrips are one thing there are no rules on, I can have as many, wherever I choose as long and wide as I choose. There are a couple going to go in when I get a dozer in the vicinity, which should be later this year ;D
Arr, Chook, you must be an old bugger like me. Flying gyro"s is a great way to spend retirement. I need something a bit more upmarket than a grader Brian. Maybe the biggest one of those seven flying disks in a hanger at area 51 which we"re not supposed to know about and if you talk about them 45 percent of the population will think you"re a nutter. It would leave no wheel marks!
Arr, Chook, you must be an old bugger like me. Flying gyro"s is a great way to spend retirement. I need something a bit more upmarket than a grader Brian. Maybe the biggest one of those seven flying disks in a hanger at area 51 which we"re not supposed to know about and if you talk about them 45 percent of the population will think you"re a nutter. It would leave no wheel marks!I must be part of that 45%.Graeme.
Funny that, Graham, if you believe in ETs 45% of the population including the Gov. think you"re a nutter, and if you believe that a God turned himself into a man and came to earth, huge Gov. backed institutional monolithical orginisations will pat you on the back!
