Aero Twin four stroke on a MONARCH
  • Aero Twin four stroke on a MONARCH
    AeroTwin four stroke on MONARCH
    Apart from the rotax four bangers which have been prototyped. AeroTwin have worked closely with Larry to configure the engine to suit pusher gyros, providing a cooling cowling and engine mounts etc.Perhaps, once you have a MLS (full flight rrpm, pre-rotator, 3-5 seconds in the air) and All Terrain G Force Landing Gear for stop and drop, with a beefed up slider rotor head which accomapanies the install of the MLS, put a four banager on it for reliability.........Then with all due respect to Roscoe and Birdy and all of Roscoe"s clients.......until you try it in this configuration, with the Aussie mods (beefed up wall thickness of tubes and plate).......Then you & I really dont know just how good it is. Though personally I have always known that this prototyping process Larry has been doing ( partially a result of customer feed back and testing testing testing) was always going to lead to a very versatile gyro indeed.Come and get me Ugly or Not!Mitch
    Mitch,Happy birthday.I like your tail..Is that a turbo I see in the photo?Cheers,Nick.
      MitchI just want take it
        Whats the hold up with the MLS pre rotator Mitch?BTW, if its your birthday, happy birthday. Have a good one !!Mean looking motor that. Inter cooled and a big turbo, better hang on !!!!
          Happy Birthday I like your Tail?????
            Then you & I really dont know just how good it is. Well !!!!!!!Wot ya waitn for man????Bring it out ere n let me sink the boot into it.Coupla Qs;Aftercooler???Wots that silver cylinder above the prop flange?How many pots?Watercooled??And how much $$$?
              Good On Ya Birdy, always asking the hard questions.
                Thanx Mitch. No, no wetty yet this year. We got sum isolated stroms late last year, but this constant f%$#
                  Thanks Bloke,Sorry about the lack of wet, most others were drowning in it. ???I just looked at my high res shot and that metal cylinder has a shaft with a splined (sp ??) end on it.The end of the shaft appears to be almost in line with the prop plate.
                    Wots that silver cylinder above the prop flange?May even be an electric starter motor ????
                      The starter motor is on the side of the engine. The silver "thingie" is the clutch drum. If you look on there web site they now have a full parts brake down for the engine.
                        UPDATE!From Larry...Intercooler top rightA turbocharger heats up the intake air when it is compressed and anintercooler cools it back down to keep pre ignition from taking place.Our Aerotwin engine will have 80 hp.
