MLS Metro Launch System Install on Blue Emperor Butterfly
  • MLS Metro Launch System Install on Blue Emperor Butterfly
    G"Day Gents,Over the last few days I have been putting the MLS unit and Double Slider Head on my gyro.The limiting factor on rotor rpm is how well the obsolete "puck" brakes hold, ie at what engine rpm they give up holding the gyro. Hegar have only got the experimental type now which are rated I believe to 1500 lbs all up weight. The old "puck" brakes are rated for a 500 lbs aircraft.Larry has advised 270 rrpm on the experimental brakes for the 503 MLS and guesses around 200-220 maybe possible with my old "pucks". ;DCheers,Mitch
    I have been using John Bull brakes for a few years now and have found them very comfortable. Before that I had Dunlop T"s.
      Graeme,I was just commenting to a fellow aviator regarding the hospitality shown to me by fellow gyro pilots like yourself! Thanks again.I presume themove to QLD went well?Give my regards to your better half.Thanks,Adrian Mitch,I am looking forward to your views once you start using the MLS. I expect there will be no holding you back.cheers,Adrian Reg
        Nice looking workshop Greg!
          G"Day Skyhigh,The wife frowns everytime she looks my way. I am set up on the kitchen table.
            Yes guys haved moved back up north. All went well dodging storms and floodwater, missed seeing Bones and his pride and joy as we had to make a detour around some water.Will be back down for the nats to catch up with all there.Mitch, I will pay for your fuel if you fly that machine of yours across the creek.Graeme.
              Gra, Mate paying for the fuel wouldn"t even be the start of it.
                and any form of suicide at this point in time is not on the agenda :-Mitch Ahhh!! The old neck must be feeling much better.
                  Fred ole Mate,Mate it"s very much better. Pain/pins and needles discomfort/etc all on the improve.How"s the house comming along? Steady, steady, way to go!
                    G"Day Gents,Last two pics.Everything went together really well apart from the pull start, which played up no matter what I did to it. The pull start rop would not retract, yet I followed the rotax manual and still iut would not function.Any ideas????I have one switch to solder in place, put the blades on get the pull start to function correctly and away we go!Mitch.
                      MLS was tested today at Cranbourne.Spun up twice. Very soft start and lots of HP pumping through this pre-rotator.I will post test data from the next test session. Today was simply testing the air cylinder ram, belt track and other components, for correct function.Awesome it is really Awesome. Full size pics in the gallery at www.rotorcraft.com.au
                        First Video and
                          Sounds impressive Mitch!Its certainly an impressive piece of machinery, certainly a bit more complicated that it first sounded.
                            G"Day Bro,I was advised my air ram may be fully extending and causing the engine to race to much. I will have to adjust. The slip clutch is designed to kick in at 2600 eng rpm, the belt will be spinning well before this point is reached and then the slip clutch lets the blades start up real gentle but they have some serious power being put thru them as the throttle is slowly advanced.Plenty more testing to come and steady steady for me these days ole Mate.Give my love to Rosie. Hope you both are well and happy. Take care Brian.Mitch.
                              Sounds seriously good, ram air huh? best way is steady as those blades are getting serious lit around 220 revs.All are well here, getting ready for the trip to Wangeratta. Sorry you are not going to be there.
