Took me new set of GG tipweighted blades for a rip this arvy n Liz had the weapon out. [ camera]http://www.youtube.com/watch?v=XFBzqBeXv4wBeautiful wings. 0 shake, at any speed up to bout 70kts true AS, cant make them shake the stick with heavy G load variations or rapid cyclic inputs, amazn amout of inertia carry and shorter cyclic responce rate to the heavier full extruded blades.Only downside is they have a little less lift
Gerry Goodwin tip weighted blades.
That was happy flying. I noticed all that green stuff lieing around. It must really be uplifting to see grass again. Usually your videos just show dust. Your cows certainly have a long wait between feeds.GrahamThat video should have come with a warning:"The footage you are about to see contains graphic images of lush, palatable green grass that may disturb some viewers"
The machine looks a like my old machine I sold to Max"s mate Ivan, when I was out there.Thats the one Crash, just its been a tad modified since you seen it last.
Crash,............... do i know you?what is the lead time on a set of these blades and approx price.By lead time i assume you mean " how long is the que".Be bout 3 miles by now i recon.
Gerry has one pace, his own. No amount of cash will speed him up coz he knows it takes time to do it rite.Does that mean a few more revs for the same AS?NO.Actualy, these 26"ers need 200ERPM less to hold the same AS as the 27" AKs that came off, so they are more efficiant.Less lift just means to pull the same Gs, you gota give a little more backstick. These are narrower chord than the AKs, so its expected they will have less lift, [ also a foot shorter] but the earlier cyclic responce means they react earlier, and rpm is gained quicker.And for all you cockiys lookn at me green feed, f&^%off, im not sharen any of it. [ unless your lookn for adjistment. ]
