GG Blades, Tip Weighted, 25 footers, cut down from a 26 foot set.Zero Stick Shake.Take longer, to lift off and climb out, than Pats. Comparing 25"s to 23 1/2"s.No surprises at speed,
Goodwin Tip Weighted Blades, My View.
Here you go Tony.
http://www.asra.org.au/smf/index.php?topic=2172.0http://www.rotaryforum.com/forum/showthread.php?t=15720&highlight=double+slider+hea d"Removing restraint of a seesaw rotor raises frequency of the lowest in-plane resonance above the excitation frequency, hopefully. a slider that provides fore/aft compliance works well in most cases but I’ve seen evidence recently that compliance in all directions is even better."Chuck Beaty RotaryForum
