We all know that the cleaner the airflow to the prop, the more efficiant it will be at converting dead dinosours into moven air, and that we gyro nuts are startn way behind the 8ball with our props follown us, but theres sum little things we can do to improve the airflow.Simple things like streamlining anythn up wind of the prop to minimise turbulance, and keepn everythn as narrow as possable to disturb as little of the flow as we can.And i accidently found anatha thing that, as it turned out, makes a big difference, at any AS.Exhaust gas.I knew that exhaust gas flown through the prop made the prop noiseyer and this effected the efficiancy, but i didnt think it had as much effect as i found yesterday.Id been putn round for bout 4 hours getn sum moos together and pulled up for fuel and other things.But wen i restarted the 912 it sounded like a charff cutter. >
One side of my [ home made]
Mitch
