Hi all,Can anyone tell me what the distance is in height from the underside of the engine mounts to the centre line of the prop flange for a 582 engine. Tried Bert Flood, but they apparently, don"t have this information to hand, which seems a bit odd as it would surley be required when working out the height of the engine mounts for the centre of the prop thrust, unless of course the height is influenced by the gear box type, so I need to enlist your collective minds, if I may.Thanks..........Pinky
Rotax 582
