AN Bolts
  • AN Bolts
    Hi everyone, I need some info to source AN12-37 bolts. Thats 3/4".for the jesus bolt. I have tried all the usual places with negative feedback. I can get the smaller bolts. Also some info on tower and teeter block dimensions for different size blades.and the acceptable clearance between hub bar and stops. Any info is appreciated. Thank you. Cheers, Kon
    Hi Kon,Try Aviaquip 03 9585 1211 sales @ aviaquip.com.auExpect it to be between 60 and 100 bucks.
      Also, ive got Jesus bolts from aircraftspruce for my single seater.
        Thanks for your response Disco and TSemler. I have tried Avaiquip and Aircraft spruce and many others. The response I get is, they cant get them as they are a special bolt. I know AN grade bolts is the way to go and I would prefer this. I will pay the $100 bucks for this bolt as my life will depend on it ,but has anyone used a grade 8 bolt for the jesus bolt. The plans I have state 5/8" grade 8. I am increasing the size to 3/4". What do you think. Cheers
          Hi KonCan"t give ya an answer to your question regarding Grade 8 gear, I believe somewhere in the building regulations it forbids non AN gear used in critical structrual areas.If i was you I would seek advise from other rotorhead manufactures E.g. Ross Symes (He may even have the bolt you desire.) His number is in the GyroNews.Regards
            YOU CAN ALSO TRY THESE GUYS. http://www.propbits.com/I have used them many many time, great pricing coupled with great service.Regards SamL.......................
              Thanks SamL, I tried them .No good mate.
                Try ;http://www.pegasusautoracing.com/pro...p?Product=AN12 CheersMiles
                  Miles you are a legend.
                    nothing, absolutely no reply from anyone.These AN12 bolts must be something special. No-one wants to sell them. I"ll keep trying.
                      Why not ring Rosco and ask him what size he uses on all his mustering machines that he has built and are still flying, I would be happy with that.Graeme.
                        I would def not use anything bar aircraft grade for jesus bolt.
                          Thanks everyone for your input, and advice.
                            Hi all ... I"m just curious... so where did/do you end up getting your AN10 or
                              I get all my bolts from rosco. Allso had a mate who crashed with a grade 8 "J " bolt, and it snapped, sending the blades off spinning. AN bolts will just bend. I show students a box filled with bent samples. Even got an AK hub bar very bent, and looks like no signs of cracks.
