Chopper can you post a photo or 2 so that I can have a look at your 5 pin plug?Regards......Chook.4 pin plug
Static Electricity ?
Hi Tony, what engine are you using? I wonder if the electric pre rotator has a combined affect with a big battery pull down and then a huge alternator imput although I only switch on the radio and gps only after I"m finished pre rotating.Its just so frustrating when you cant get to the bottom of a problem. I went flying this morning and the new radio is very clear and it certainly is crisper coming in to my ears. Got to do some distance testing to see what happens.
So Chopper have you fixed it or not?You can still send me those piccies to waynfwlr@exemail.com.au if that is easier.I may be able to organise some better cable depending on what I see.Chook
Chopper I have just re read one of your other posts - are you still using those insertable earplugs? I suspect that the fine wire connection between those and the main lead is where you are having your problems? Send some piccies. If its the wire I suspect that they are using then it will be better to crimp that part of the connection because where the solder ends and the copper continues is a susceptible fracture point. There are other tricks which we can also employ. Send piccies and some close ups of the connections.Chook.
So Chopper have you fixed it or not?You can still send me those piccies to waynfwlr@exemail.com.au if that is easier.I may be able to organise some better cable depending on what I see.ChookFixed ? well, only had limited tests so far but I can most certainly hear a lot better with this 3100 GME although Rosie thought I sounded "quieter" than before but with the same amount of engine noise [not electricl] but that was on one of the uhf"s thats come out of the gyro so we need do a test with a new radio. Talked to my mate and he reckoned I sounded very clear so we still have the new aerial to install and a new flex lead from the 4 pin plug to the helmet to re new and put on the ferrite resistoers.Yep, still using
Thanks Chopper.Yep - looks like it needs a birthday. Ok, the bit I would check out first is the plug that fits into the front of your radio on the left hand side with the curly cord. Under that cover is a small plug that requires a special tool to crimp the wiring into the modular plug. It"s probably been ages since it was looked at or replaced and that is the first point at which both the microphone and the headset exit the radio and may be where you are getting the problem. You obviously know how to remove it because you have swapped the radio over. Look carefully at the gold pins - they should be clean with no corrosion (green). With the weight of the curly cord bouncing around it causes stresses in the copper in the cable. Without test gear I would just cut that plug off about 3" out and re terminate it.When looking at your 4 pin plug I can see corrosion around the outside edge and suspect that the male & female pins will also be suspect. That is a common plug & socket which I can source for you here in Perth if you need to. Similarly the the modular plugs I can get but you will require that tool to crimp it.I think I can count 3 connections in your earphone connections between the inserts and where it will enter the radio. There is probably another because the 2 earpieces combine into the "Y" and end up on a 3 pin plug. This would indicate to me that at that point they are still indepenadant (or in stereo mode). Do they go to some electronics "box" after that? Does the other end of that curley cord coming from your radio go to a "box" that needs power for it to run?Ok lotsa questions still, so I"ll stop here and let you digest this lot.Chook.
Thanks Chopper.Yep - looks like it needs a birthday. Ok, the bit I would check out first is the plug that fits into the front of your radio on the left hand side with the curly cord. Under that cover is a small plug that requires a special tool to crimp the wiring into the modular plug. It"s probably been ages since it was looked at or replaced and that is the first point at which both the microphone and the headset exit the radio and may be where you are getting the problem. You obviously know how to remove it because you have swapped the radio over. Look carefully at the gold pins - they should be clean with no corrosion (green). With the weight of the curly cord bouncing around it causes stresses in the copper in the cable. Without test gear I would just cut that plug off about 3" out and re terminate it.When looking at your 4 pin plug I can see corrosion around the outside edge and suspect that the male & female pins will also be suspect. That is a common plug & socket which I can source for you here in Perth if you need to. Similarly the the modular plugs I can get but you will require that tool to crimp it.I think I can count 3 connections in your earphone connections between the inserts and where it will enter the radio. There is probably another because the 2 earpieces combine into the "Y" and end up on a 3 pin plug. This would indicate to me that at that point they are still indepenadant (or in stereo mode). Do they go to some electronics "box" after that? Does the other end of that curley cord coming from your radio go to a "box" that needs power for it to run?Ok lotsa questions still, so I"ll stop here and let you digest this lot.Chook.I know what it needs all right and as the guy who built that gyro says, its like an axe head thats had many handles and the time is coming to buy a new axe !!Okay, questions. the plug that fits into the radio is original,,,and the wire back to the female 4 pin plug as is he female plug.The lead and plug coming down from the headset is going to be replaced..plus we will do the one from the radio as well. All bits I can source from Mildura plus I know of a bloke who can do and will have the crimper necessary plus does very good soldering work etc There is a tube that comes down from each earmould, joins at a Y connector, then plugs directly into the external speaker plug on back of UHF. That lead you see there is a brand new lead from one end to the earmoulds so I"m very confident its working well, yes, you get streo, you can plug it into a cd player etc, and its got great sound. It doesnt have any electronics box, everything is somehow self contained internally. The lead I replaced only had sound to one ear so thats why I replaced it.
