A 912 without a propeller, when you start it what revs does it rev to ?? Thats at throttle closed position.
Rotax 912 Engine questions
Well there was a video of that guy who done the 914 efi mods, he was running a 914 without a prop,,, to full noise too, because it was efi, the fuel just cut off, so it limited it too the max revs.but i would say if it was set up to idle with a 72" prop at say 1800, i would think it would easily get to 3k prob more with no prop, cause at 1800 the prop is pushing a lot of air.
Cant say from experiance Brian, but it wouldnt be pretty.The prop ona rotax 4banger is its flywheel. Ever tryed run"n a high compression 4banger without a flywheel?[/quoteGuess a suby isnt a high compression banger cause it makes no difernce prop or no prop.Anyway, appears no one here has actually run a 912
