Does anyone know what the part number ect for the actual bendix for the RAF prerotater, it would cost more in freight ect then the part if i got to get 1 from SA.Any help be good.
RAF prerotator bendix
If it"s only the teeth that are worn, recently we had the problem on a sparrow hawk and we unrolled the clutch housing on a ford/ holden drive ass. and removed the pinion teeth, ground a bit off it with angle grinder, and it fitted and got us out of the poo. (the pinion didn"t go as far into the ring gear as the original) The drive assembly was off a dirrect drive bosch starter.
