Hi All, I am thinking of building a airfoil stab to be mounted in the prop blast.So what I want to know is if the airfoil section used is asymmetrical or symmetrical? How important is the choice of actual airfoil? I am hoping the actual airfoil is unimportant because then I can make it to suit the spars and not have to worry about ribs to keep it the exact shape.Mastic
Horizontal Stabilizer
Hey Eric, yep patroney prop,71 inch. The adaptor came from SA, Yes still making the pods.Mastic, the forward tilt is basically to keep the nose up the faster you go,the engine is level on Tall Tail models.And contrary to some belief there is abundance of rudder even with engine stopped.M Barker
