AN bolt and nuts
T-bird,If you haven"t already done so I recommend you get in contact with your nearest Tech Advisor. TA"s are listed on the web site or in the Gyro News. A TA will be able to assist you with this sort of stuff and probably save you allot of rework and the frustration that goes with it.Rob
I think it"s just that most companies have it on their own web site. the bigger companies have usually got the stock but you have to buy a minium $ line value, and probably the others are more user friendly. I never have, but some people buy direct from overseas. if you "ask again" here, someone should be able to point you in the right contacts. once you have " the chart , it really comes together as the correct part required. hope this helps.
