Theres alot understood bout the physics and dangers of PPO [power push over] caused mainly by a high thrust line tipping a machine over forwards if the rotor lift is lost for a certain amount of time.How much thought has been given to the possability of a PPU [power push under]???[}
]Some of the new age machines you see get'n round now have the TL below the COM, and in some cases, along way below.Do the people fly'n these machines know that theres an equaly dangerous possability of a machine being flipped over backwards or are more susseptable to a torque roll over??[xx(]IF....... a machine started to tip over backwards, the point of no return will cum much quicker than in a forward PPO.[xx(][xx(]Just some food for thought, I'll leave the scinarios that could cause this to happen to your imagination.[
]Ignorance is bliss............but only till you realise you were.You can always get the answer you want, if you ask enough experts.
6.96
4.74
6.7
]The reason I never did it before now was coz it was a low priority.IOW, it wasn't dangerously unstable.Also, I'v got a new hart for it in a box with more power, so I thought I mite as well frig around with the COM before I drop it in.That said tho, its obviosly less prone to PPO now.Anyone in the market for a very reliable 80hp 912.............just run in, never coughed,farted or used oil???[
