Just wunder'n wot the RAF frame/rotor head can handle.[
]I recon i know now wot a Rosco can handle [
][ anything but rotor strikes], but i wunder if theres a limit to the flog'n you can dish out to a RAF.I'v used it a few times to work critters and tho its alot slower to manouver, it can still do the same stunts as the little ferel, but for how long???[B)]The head for instance. On the ferel[ a Rosco] it's alot beefier than the RAF and its usual opperating weight wouldn't be half that of the RAF.My Raf could be thrown bout a bit harder than the average one coz its lighter [ -70 odd kg with the 914 and i'm only 75kg wring'n wet[
].] and theres less artificial weight from the lowered TL[ only under power obviosly].I know they were'nt desigened to do anythn but putt round on cross countrys but even then you can get caught in some frame/ component stressing air[ especialy if there was a couple o fatys sitn init[xx(]]. Would the engineers have factered this in to the build strenght?, or did they think that noone would ever get caught in crappy air?[V]I'v never heard of anyone who 'throws his RAF about like a heavy feather'.Is there anything else i should consider, should i get the urge to wring its neck[}
] besides structural integrity??Ignorance is bliss............but only till you realise you were.You can always get the answer you want, if you ask enough experts.
