Galvanic Corrosion/Dissimilar Metals
  • #16
    Young Mr Horribulus..How is galvanic effect avoided when an aluminium rivet passes through all the coatings and base metal when, as it is 'set' by squeezing it up tight so that it expands in the hole, not to mention the steel rivet shank within the rivet head, that it would not come into contact with both the stahl and aluminium?I look forward to your illucidation...Nicholas TomlinAlarmist - www.alarmist.com.au - we scare for you
    • #17
      Co-incidentally, I will measure the length of my push rods so you can help me out..thanks..Nicholas TomlinAlarmist - www.alarmist.com.au - we scare for you
      • #18
        • #19
