Birdy,I see you pulled your post and I edited mine, here however is the extention of that discussion.As you, I noted Allan"s last line of his post. I was not going to comment here but as you raised the comment further I felt I should add my thoughts on the loading issue. I did some quick calcs, I dont know what the pilot weighed but I recollect he was, not to tall and light frame.If we give pilot weight at 85 kgs and fuel at 40 litres, approx 30 kgs, we"d end up with;Pilot and Gyro full fuel......1.2 lbs/sq/ft Disc LoadingPilot and Gyro low/no fuel......1.086 lbs"sq/ft Disc Loading
Disc Loading....what is too low?
 G"Day Chopper,Likewise hope you and Rosie had a enjoyable Christmas and all the best for the new year.No one wants to discuss disc loading parameters, pros and cons etc?Mitch.Yes, it seems disc loadings are not that worthy of discussion which is a little surprising as loadings are relevant to safe flight. We had a quieter Christmas /new year down at Rosie"s folks. We usually do a Christmas lunch at Mildura with my sisters, then drive the 300K"s down to Rosie"s which makes for a big day so it was a pleasure not to have to drive anywhere Christmas day. We got caught bad a few years ago, the Nissan"s rego comes due on the 23rd December and we had only had it for 12 months and forgot that the rego was due on that date so we had the lunch in Mildura and was heading over the bridge at Mildura where we were pulled over for a random breathalyzer and Mr policeman put us off the road plus gave us a hefty bill to match so that was one year we didnt get to Rosie"s. Needless to say, the Nissan"s rego is now an important part of chrisy celebrations !!
 The only time iv found light loading to be a hinderance is wen your tryn to do high rate inputs, it just dont happen.Id never say light loading would be a hazard in ruff stuff.Everythns relitive.Light loaded blades have a shorter rev range for given AOA changes than heavier ones.
 Dont know any details bout the moments before the bingle, but i could picture run"n outa cyclic control range if the hang was only 2.5*. Itd be very hard to get level if you were nose high, slidn backwards and didnt chop power. Infact, impossable if you didnt side stick, and only pushed forwards.Im not go"n to speculate ere, but theres a few easy ways to get into trouble if you dont have enuff forward stick movement, and dont know the alternitive control. Itd be very hard to get level if you were nose high, slidn backwards and didnt chop power. Infact, impossable if you didnt side stick, and only pushed forwards.Im not go"n to speculate ere, but theres a few easy ways to get into trouble if you dont have enuff forward stick movement, and dont know the alternitive control.
 But i dont have much of a memory for names.Must be getn old.
