I'v also posted this on the yank forum, coz i like to know wots go'n on.A simple question to those who have a thorough understanding of rotors.The other day, while geting a bit hot under the coller at work, i found myself in a sticky spot.At bout 40pmh and 5' off the ground, i was confounted by a tree, a big tree that was too close[ only 20' ahead] and too high [20' above me] to get over.It was also a little too wide to duck around in the normal fashon without some serious trimming happening.Instinctivly, i chopped power and [ quite volently] heaved the stick left and back. Much harder than i would normaly, coz normaly i'v got a bit more room to move.The machine basicaly stoped instantly and with the aid of some rudder, was pointing away from the tree. With the reapplication of full throttle and holding the stick back, i staggered to safty, missing the tree and stayn off the ground. IOW, a right angle turn on the spot and without any alt loss. [ says sumthn for gyros ay][
]The only thing that concerned me was a loud and distincet 'chopping' sound.As i was 'staggering' away to safty, i looked back, expecting to see part or all of my rudder missing, coz thats wot it sounded like. It sounded like a rotor chopping at a plywood rudder.[ bout 5 or 6 chops]Knowing now that it wasn't the rudder getn trimmed, and i know i missed the tree[ allbe it not by much], and theres no other evedence of anythn hitting the rudder or rotor, i'm wundern wot made the noise.?????Was thinkn maybe sumthn to do with the blades airodynamicaly, like a partial stall [ huge cyclic demands]or maybe this new 912 don't like such abrupt full power changes and pinged or sumthn.?????It don't realy matter, coz i'm still alive and i'm not plan'n on do'n that sorta move any time again soon, but if i knew wot made the noise, and it was nuthn detremental, then with a bit of practice, it could become a handy move in my line o work, if you get my drift.[
]Ignorance is bliss............but only till you realise you were.birdy, here.
