This Weeks Quiz??
  • This Weeks Quiz??
    You have just gone solo. So now the real flying starts, just you in the air to make all your own decisions.What would be a good set of guidelines to follow during your first 10 hours of solo flying?[?]Why are these sort of guidelines important for pilots?[?](I'll suggest one thing is to set some rules for wind conditions. Maximum wind strength and maximum crosswind allowed for you to fly.)RossB
    Ross,One rule,Repetition, repetition, repetition on crow hops and take offs, then engine outs, perfect those things and the rest of them will *mostly* look after themselves.. learn how to crash, then learn how to fly. Stay close to the strip until you get the engine out landings right.Cheers,Nick.
      A couple of things to keep in mind during those first few hours.LOCATION: If possible only fly in a location you know well. The first ten hours or so, is not the time to be flying from new locations. If you need to fly from a new location, you need to get some input from your instructor on the suitability of the airfield.PLANNING: Yes your now on your own, so you need to take some things into consideration such as your fuel burn and your flight time. Set your self a limit of say 30 minutes for each flight for the first 10 hours or so.BRIEFING:WEATHER: You will have checked the forecast before you arrive at the airfield. Is the wind as predicted. LIMITS: Set yourself firm limits on wind strength and crosswind. Say 10 knots with a maximum of 5 knots crosswind component.NOTIFICATION: Who did you notify of your intention to fly. You should have someone on the ground keeping an eye on you. AIRCRAFT: Stick with your own machine, this is not a time to be flying a different machine. That can wait till you have some more experience.ONLY FLY OVER STUFF YOU CAN LAND ON: Tiger country is for tigers. If the strip is surrounded by tiger country, this is not the place for you to train.AVOID CAMERAS
