Some things to think about.How do you know when your behind the power curve? What are the indications? RossB
Am I Behind The Power Curve???
Gidday Ross,Tim and Birdy are correct in my opinion. Nick is stirring I think!There are 2 common "behind the power curve" scenarios. The most common occurs when a pilot tries to force the gyro to fly on takeoff before it is ready .... horseing it off is a common term for this "manoeuvre". Recognition is afforded by the fact that the nose is abnormally high compared to normal, and the gyro does not climb. It remains airborne in ground effect, and may continue like this until obstacles determine otherwise, or in an effort to force a climb, the pilot raises the nose even further increasing the potential for a blade strike behind the gyro. Recovery may be effected by lowering the nose slightly to establish a gentle rate of descent to touchdown. Chopping the power in this situation will cause an accident'. Solution? Don't force the gyro to fly during takeoff. Gyros originated on Venus, so they do things when they are ready, not before!! The second scenario involves the much discussed down wind turn. Despite the many varied explanations for why this phenomenon occurs, the fact of the matter is that you have full power applied with the nose high, and the gyro is still descending. The consequences near the ground are the same as for the takeoff scenario. The solution? Dont be there!Herein lies my opinion.Regards,Waddles.
Another indicator is the sluggish feel to the controls. Larger control inputs are required to correct any deviation to track and the aircraft response is also much slower. The rudder control is still responsive if you have plenty of power on , the main changes are in roll control. If you've ever paddled a kayak half full of water, that's the same feeling.RossB
