Thats right Frankie.The new system as I understand, strongly recommends pilots not to overfly, and to join at 500 ft, (ultralights with speeds below 55kt) either 45 degrees down wind or midfield crosswind, or straight in approach.You can overfly if you realy feel you must, but not over a CTAF(R),without a radio.Due to our generally slower speeds, new circuit hight, and smaller tighter circuit, as required by the new regulations, overflying should'nt be as greater a requirement.Sounds good!!!!!Regards Sam...[
71.37
]http://www.asra.org.au/forum/topic.asp?TOPIC_ID=729
