Hi Waddles, Laszlos Raf was in his shop getting an ej_25 fitted.I have flown a Raf with a stabilator (the beautifull one for sale in the gyro news) and all it does is act as an aerodynamic trim, also as the speed gets faster makes it more difficult to move the stick quickly. On the ground there is no trim spring pressure to push against to hold the stick forward. That is great. The Raf have used an incorrect torque tube offset and requires a lot of trim pressure when flown dual, so the lack of trim spring pressure on the ground is a benifit. I couild not find anything positive re stability with the stabilator. Every time a gust was encounted the machine would diverge in pitch if left hands free, and a PPO would ensue.The Raf stabiliator is an aerodynamic trim that makes it more difficult for the pilot to accidentally give too much pitch input at high speeds. Not even a good "bandaid" measure to the large thrust line to CoM. An effective h/stab is a far better "bandaid".Raf owners, conduct our Raf mods and have an almost perfectly stable gyroplane.Laszlo conducted my flight review in David Browns modified Raf that was signed of by Adrian. I trimmed it and took my hands off and we flew through rough and smooth air and the machine was stable. I took David after Laszlo had completed the paperwork. We conducted the stick free stability tests at 65 mph. The first round of tests showerd that the machibne slowed down more that the 10% allowed by the stabdards when full power was applied. I reduced the negative AofA of the stab approx 1/2 a degree and the following tests were perfect for thatr TOWeight. Trimmed at 65 s/l hands fee, apply full power and the speed would increase 2 mph and then the nose would rise and the speed would stabilise at 65. The same with reducing power to idle, the machine would slow a couple of mph and then the machibne would lowers its nose and settle into a glide at 65 mph.Flew as cross country instructor this morning in the Magni, the only gyro that I have flown that surpasses my Hybrid for stability. Bugger having to get the freezer suit out though!!!![
]Aussie Paul.[
]Aussie Paul.[
