News Flash,Allan Stockdale a member of the Bindoon group & recent convert to gyro's from the trike world has been signed off by Rob Patroney and departs Bunderburg Wed 23rd November in his 912S powered Gyke to fly to Bindoon in WA. Initial planning suggests that it is a nine day flight ave 45kts and 5hrs per day.I encourage all of you to log into Allans web site at www.alfa.au.com to give him support and follow his trip.Birdy,Check out his flight plan as you may be able to use some of his contacts for your trip.regards,Adrian.
Bunderburg to Bindoon by Gyro
Na Ecko, this comp thingy won't show me, gota wait for the MF to cum back to fix it.Harts Range??? Wunder if e's guna drop in, i got plenty o fuel ere if e's interested.[BTW Ecka, he didn't stack it, he got T bared.............. by his sister.Bloody kids].Ignorance is bliss............but only till you realise you were.You can always get the answer you want, if you ask enough experts.
Hi All,I am very sorry to read this evening that Allans trip has ended early due to a willy willy encounter at Warberton in West Australia. Please refer to the web site for Details. I can appreciate the power of these willy willy's from a personal experiance as can Peter Barsden does, so to all Gyro pilots please never underestimate the power of them. Des Garvin W.A.
Pick,A willy willy or dust devil, is a bit like a localised mini tornado.In most cases you can usually stay on your feet if one passes over you but it is no plce for a Gyro !Sorry to hear about the accident Guys but you have still set a record.Cheers.Image Insert:
16.17
??????????????????Wot happened?Was e ona ground when it hit?I'v had plenty of them go through the camp with the machine tied down, and flown through plenty more.Cumn unstuck was never a problem.Sorry to ere the news either way tho.Ignorance is bliss............but only till you realise you were.You can always get the answer you want, if you ask enough experts.
Guys,I spoke to Allan yesterday and it appears that the "willy willy" struck as Allan was about to flare and land. Warburton is a reasonably large bitumin strip that hides willy willys because you cant always see the dust tails when they head your way. Bad luck but still a great effort to get that far. Adrian.
28.79
