Ok people lets say some one wanted to build a machine, where can they locate parts they need, like fibreglass suspensions, all the hardware ie best place to order an bolts ect.Lets put up ideas for every one.I spose it just be easier to get it built by some one else, but not all of us have that much time.
gyro bits
Des,Structural parts 6061 T6 as above. Remember you can fashion alsorts of brackets etc from cutting the 2x21/2.Cheek plates use 5083 marine grade plate -5 or 6mm and can be sourced from any boat builder or ComalcoNon structural ie pod mounts etc
surely cant leave out gerry with his seat tanks and rotors. he has a very wide chord extrusion, and rob also has a composite main spar, as well as rotor heads, as do others. this list would be good in the mag for when newbe"s can start getting them at the news agents stand.how far away is that anyway guys?
