Had an Ag pilot do a bit of spraying on a block in some rough country in the lower alpine region of Victoria. The differential in elevation is 1,500ft with some bloody tight gullies. Funny lot the Ag pilots, the last 6" of each wing had a few dints in them - from bird strikes (but the bird was sitting in a tree at the time)!!!! Yet start talking about gyro"s and they stop talking - gyro"s are just too dangerous!!!!Anyway back to building the highly dangerous gyro (all relative to me) ;D. The whole idea of this forum is to learn from others so as to minimise that risk/danger.I have done a bit of machining of the rotor head, the main bearing block and the spindle forks. The main bearing block is symmetrical so it is easy enough to hold in the 4 jaw chuck. The teeter bearing seat on the spindle fork was totally off centre so that had to be clamped onto the face plate and then bored out. I centred up the hole in both cases by marking out the centre spot, centre punching the spot. Located the dead centre in the tailstock into the centre punch, then tightened up the jaws (slowly and evenly) or the clamps on the faceplate. To get a good finish I lubricated the last few cuts with a squirt of WD40. Another small trick when making 2 of anything, I always Superglue both blanks together and then start machining. This way you can be sure that both will be identical and it almost halves the total time to make them. I have also glued the spindle forks to the bearing block to drill the bolt holes - a lot easier to make sure that everything is correct before you drill and you only have to mark up one side and then drill all the way through. I always let the glue set for an hour or so and then come back to it with fresh eyes, double check everything and then do the machining.
Hope everyone has a great New Year and 2012.
