Found some concept art.I"m guessing it looks *sort* of okay from an aesthetic point of view, but I"d be interested in hearing what the seasoned professionals have to say about the practical ramifications of such a design?
Good in theory... but not so good in practice?
Hi Quoj,The pictures are certainly a snappy piece of concept art. I am not on the forum much, probably spending far too much of my spare time concerned with gyroplane thrust lines etc as I wade through the hundreds of fleet survey responses.My "informed instinctive reaction" to the side-view image is that it"s a superficially appealling design, although I would consider that the front wheels should be reduced in diameter by 1/3 and replaced with spoked wheels and the spats should be abandoned. The engine and propeller axis needs to be raised spinner-upward by 10 to 15 degrees; the vertical stabilizer needs to be increased in height by 70% and the taper of the rudder to be not so severe; the horizontal stabilizer needs to be relocated so as to be level with 1/3 prop blade span down from the prop hub; the snake-tongue tail skids eliminated and replaced by a wheel; the mast needs to be raised a little, those strange triangular elbow-knocking fairings need to be eliminated; some form of minimal instrument pod needs to be fitted; and, a single safety skid would need to be fitted to the front under the rudder pedals to safeguard against a nose-over - and, of course - some form of throttle quadrant needs to be fitted!With all that said, after all these mods it might become practical.Cheers,Mark ReganMelbourneASRA Board MemberASRA Technical Manager
Have you got the right bloke?
