Conventional to Overhead Cyclic Controls
hello PAUL, the controls your describing is what I would think would be on a GYKE. rob patroni had these , being a gyke pilot. I had been in the back seat with him and noticed he could do everything he wanted , including put it down on the spot where ever he wanted. there could be a photo of rob sitting in his gyke with controls in a mag. HELLO MR EDITOR ROSS, can you use your magical powers to find something there for PAUL.
Hey 4CA,
Rob was the only instructor endorsed to train pilots on his gyke. His rating is no longer valid. To my knowledge, there are no other instructors qualified to train with reverse sense overhead controls.So, unless you're going to train yourself (definitely not recommended), stay conventional.
Regards,
Waddles.Waddles
- 1 like
hello paul, something is wrong if you used more than 1 carbide insert. it should of been able to handle 4140 threads. vibration is a killer for carbide. not sure what you've got but hope that may help for next time. probably about 10 or 12 years ago there was a story in the mag of a gyro that was made somewhere, like SOUTH AFRICA. it was a stand up version. even in my younger years , it looked crap. but it also had a over head style control. cant remember if it even showed a mixer or gyke style. allans message of no gyke trainers available should be kept in mind. with normal controls I can rest my arm on my leg if needed. I see trike pilots seem to have super glued gloves onto a horizontal bar control . seems to be saying it is easier to keep hold of over a period of time. not sure what you would do with a vertical overhead stick. if ever you got rotar flap that upside down stick would be looking at puncturing some leg parts.
In the late 70s I built a trike and plonked my hang glider which i used to fly with a 10 hp engine and long shaft strapped to the keel on top. I mounted a 10hp engine with reduction on the trike and promptly destroyed it twice trying to orientate to the back to front stearing. I finally mastered it by thinking of my bum instead of my hands. I would never use the system on a gyro. Standard control stick is natural. You don't have to think. I went to the Philipines shortly after my second trike crash with badly skinned knuckles and the locals accused me of being a street fighter
