Can anyone let me know the best method to get a warp drive prop into balance? Having been told everything from lead shot drilled into the ends to lots of hairspay on the lightest blade...your experience would be very much appreciated.The chips have just been filled and its now a fair way out as you can see.DaveImage Insert:
32.85
32.85
rill and tap the 200 base plate at its centre to take the M10 bolt.Screw the nut onto the shank of the bolt, put a washer between it and the base plate, screw the bolt into the base plate and tighten it to snug, cut the head off the bolt and then cetre pop the cut end, drill it with a 1/4 drill so a rebate exists in the top for a ball bearing to sit in.Mark out the alloy plate on the centre [from diagonals] with the PCD for the prop and centre pop the middle and drill to 2mm deep with a 1/4" drill, mark two bolt holes diametrically opposite and drill to take the propeller mounting boltsBolt the alloy plate to the propPut a bearing on top of the bolt and base plate in the drilled recessPut the prop on the spindle and make sure it engages the bearing at centre, it will click as you roll the prop over the engagement points.Place the bulls eye level on the plate at it centre and see how far out of level you areGet some 'known' weights and add them to the weight of the highest blade, note the weight and the centre required to being the prop into balance.Modify your blades to suit, with my timber two blade prop I had to shave about 10 g off the leading edge of one blade and same for the tail edge of the other, I also had to take about 60 g off one blade all over, result was a very smooth prop.Here's a sketch:Image Insert:
3.02
62.18
