Front wheel turning angle
  • #16
    Good idea Pete to have push rods on both pedals. Having the front tyre pumped up helps turning as well...for all of you who are a bit slack with tyre presures.BrianPooncarie NSW
    • #17
      • #18
        Lloyd, a Raf is a total of 25 degrees and my mate Chums is a total of 75 degrees. TYhis nose whell set up does not turn enough yet and I need longer bits of 1/4" unf allthread to stick out past the rod ends.This is how it should be done Pete!! Since this pic I have replaced the sprigs with stronger ones. This allows thje nose wheel to self align if the rudder pedals are not in the correct position. Very handy with a cross wind and the stgudent lets the nose wheel touch the ground while balancing on the mains.Aussie Paul[]Image Insert: 83.58 KBImage Insert: 79.94 KBwww.firebirdgyros.com
        • #19
          • #20
            Bloodyell PB, you typn is getn as bad as mine.Ignorance is bliss............but only till you realise you were.birdy, here.
            • #21
              • #22
                quote:Originally posted by birdyBloodyell PB, you typn is getn as bad as mine.Ignorance is bliss............but only till you realise you were.birdy, here.Hehehehe My big fat fingers!!!![] I want a key board that is 50% larger!!!![^] I thought you were just ig[]norant and couldn't spell Birdy!!!!Aussie Paul.[]www.firebirdgyros.com
                • #23
                  • #24
                    There is a theory that has been developed around these parts Paul that your persona is turning into a [][][8D][:I][][}][][)][B)][8][][8)][:0][!][xx(][|)][:X][^][V]. It would be unfortuate if all you became in the end was a [?]PeteBairnsdale,Vic.
                    • #25
                      • #26
                        I have no idea what you mean Pete. Obviously your sense of humour is too obtuse for me.I prefer to say what I mean!!Are you coming to Torumbarry Pete[?] I might need a machine to fly!!! With Chums I have my knees up around my ears. I prefer to leave that to my nocturnal activities.[] Geez, Pete look what you have done to me!!!![]Aussie Paul.[]Aussie Paul.[]www.firebirdgyros.com
                        • #27
                          • #28
                            I am hoping to Paul[] but my plans over the last couple of week-ends have been necessarily changed due to circumstances.[]Gee I think I must have caught it.[xx(]Pete[]Bairnsdale,Vic.
                            • #29
