Rotax 4 banger props...help
  • Rotax 4 banger props...help
    Hi Folks, what are you guys, with Rotax 4 bangers pushers, using for props??Aussie Paul.
    Paul,I favour Warp Drive 68 to 70" 3 blade on gravel strips because they are easy to repair when a bit of "iron ore" or a sucked up
      I have the Bolly 3 blade carbon with urethane insert. A very tough leading edge for Oz conditions. Highly recommended
        Ok, thanks guys. It is a shame that Rob doesn"t make a prop for that rotation.Aussie Paul.
          Ok, thanks guys. It is a shame that Rob doesn"t make a prop for that rotation.Yeh, same ere PB. But im opposite to everyone else. ???Hada brolga, wouldnt blow the ash off me smoke.Run 72" WDs on the ferel for low inertia, easy patchups [ coz they dont like anythn bigger n a grain of sand], and are quick/ easy to replace.Hava 68" mag on the 914, coz its bullet proof, quieter and inertia aint a wurry ina cruiser.
            Rob mentioned he might be making a prop for a rotax powered fixed wing he gotIf he finds time that is
              Pusher or tracter?
                Three blade bolly on mine
                  Pusher or tracter?puller
                    I thort he already made wide chord pullers for 4bangers.Its the pusher he hasnt got.
                      I thort he already made wide chord pullers for 4bangers.Its the pusher he hasnt got.That"s how I understand it Birdy.Aussie Paul.
                        ah right, I thought you could just turn em around. Spouse the tips would be pointing the rong way
                          IVO medium 70"
