I am in need of a piece of 2"" x 4"" 6061T6 box with 1/8"" wall thickness 1450mm Long.
6061T6 material
Hi Mauds, not sure about the large box section you are chasing but these guys should have everything else you needhttp://www.thyssenkruppaerospace.com/materials.htmlOr these guys http://www.airportmetals.com/See how you go. I think performance metals in Sydney will stock some of what you are chasing, they are easy to find on google. Hope the project goes well.Matt
G"day John,Try Metalsdepot www.metalsdepot.com I seen that 2"x4" 1/8mm size you was chasing in the 6061. Pretty sure they said they sell in lengths of 2ft increments.
Hi guys. Can someone please help?
I see there are no posts newer here than 2013 that I can see??
I am building my 2 seat gyro and need a couple of meters of mast material (RHS) with radius inside corners and 6061-T6 temper. The section I am trying to matchup is 63mm x 50mm or 2-1/2" x 1-15/16" for those imperially minded. Does anyone know where I can get a supplier of these most exotic materials in OZ land? If I have to I will even convert to 6061-T6 round tubing if someone knows where I can get that either?
I look forward to a response.
G'day Phil,
SEQGC have lengths of keel/mast material in 6061T6. I can bring home from Wondai on Jan 15th or you can come up to Wondai and collect yourself. Not sure of the price but will check it out for you.
Also. I've asked around re your blades and so far, no-one can identify them. However, if the hub bar is only around 19 mm, it is not acceptable on a two place gyro and could possibly be 2024 alloy which is banned by ASRA for that purpose. Additionally, the bolt pattern is not good at all. They are normally staggered, not opposite each other like yours.
Waddles.Waddles
