Tony sent me a PM about duel ign. dist. into duel plugs. I was unable to work out on this new forum how to answer a PM. Anyway Tony I have only made up a Dist. to suit duel sensor/igniters into single plugs. (Using a HT 'diode' to allow 2 coils into one dist. cap) To suit 100% duel ign. you would be best try and locate the original sub. 4 dist. which I asume has duel HT outlet, ect. I've seen one 15 yrs. ago on Russes flying pencil but can't remember the layout.
EA81 duel ign.
Max......before I go delving about.....that single seater your way built by Colin ? ( forgot his name ) he had a duel setup on it, 2 independent circuits, that feed to the original spark plug. That machine I think...is still NT.
parts were easily sourced. Mine was similar, but 2 spark plugs per cyl. ( sub 4 heads ) the guy to chase there is Bundaberg guy.....had a engineering shop, forgot his name. ( was mates with patroney ).... Jeeezus, his name is on the tip of me tongue.If you aim for nothing, you'll hit it every time
Here ya go.....
twin ign ea81
distributor mods by " performance Ign Services" Melbourne.....98723644
double coil thingo....( automatic coil selector) made by MSD ign, part number 8210, sold by Rocket industries NSW. 88251900
you send your dizzy to Melbourne, they modify it to 2 pickups inside, the rest is easy.
then there's the Bundaberg method ( 2 spark plugs per cyl )If you aim for nothing, you'll hit it every time
The X Collin craft is still here Rus. It has been re- dezigned and flies well. It's actually for sale at present. Advetised on the Gyro buy sell swap and the gyro face book. I coppied his ign. system. I think there's no such thing as an inventor. Except maybe the clever dick that invented the wheel. From then on we just borrowed each others idea and added a bit more.
You bloody tight ****. 😉......bet when you take junk to the dump, you come back with more than you took.Originally posted by mad max View PostLove Zip ties. Worked in the Auto elect trade for years before they were invented. If I cut one I always cut the correct side and use it again on something a bit smaller!
