Tony - dual ignition - extra weight and more things to go wrong.
With normal maintenance and good pre flights when was the last time we had an ignition failure with an ea81?
I would like electronic ignition purely because the points eventually wear.
Currently my EA81 spark plugs are running very white so I am in the process of going up one level of richness in my Weber and using the next colder plugs (BPR7ES) in lieu of the B6ES series.
Regards..........Chook
