If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Thanks but no thanks russell.Are they just an inline fuel pump?You"d also only want low pressure wouldn"t you because you wouldn"t want to over run the float needles.
