Stone House Construction.
  • Cheers Paul.Graham, cant wait for the boredom to set in.
    • Aye Mitch, Either you photo shopped that first pic of the last 3 or you put on a bit of weight since I last saw ya
      • Cheers Des.Had to spend a day cutting out the rebate for the double door step tread.Used a nine inch cutting wheel and a smaller grinder and a concrete bolester/chisel.The door step treads dont come with a drip groove, so cut that in,
        • Get the Doors stained and hung.
          • Back to the built in robes and ceiling/wall lining with Tas Oak VJ boards.These two pics show the basic plan.End cupboard space at end of hall wall. Ply board to be installed in between the two closely placed vertical studs. Then ply placed on the floor stud dividing both sides of the back to back robes.
            • Building the robes
              • Get the Doors stained and hung.You are doing a great job Mitch, I could even say your well hung ( for a door fitter).Graeme.
                • Hey "Big Fella" you"ve bin as busy as a one armed brick layer in bagdad, the house is looking schmick. Matt.
                  • You are doing a great job Mitch, I could even say your well hung ( for a door fitter).Graeme.Not to mention his huge stones
