My machine is an open frame Rotax 582 powerd pusher, see pic.I am currently running Jack Alan 23.5 ft. 8 inch cord blades.They fly realy well, but with the 70 lt tank full of juice it realy struggles to climb. I havent a VSI yet, but feel it is probably climbing at around 200-400 ft p/m at full power. Speaking to another blade manufacturer I was told if I was to increase the blade length I would inturn increase my machines rate of climb, which is what I want, but also enable it to fly faster.He went on to explain that a larger rotor disc will fly at a reduced A of A to produce the same lift therefore reducing the amount of drag produced.This does make sense, but has enyone done the above and found this to be correct. And were their any adverse effects due to over rotoring the machine. Regards Sam. [
]Image Insert:
75.86
]Image Insert:
]Image Insert:
