I fly a Rosco framed 912 ULS WITH 2700HRS on the clock. There must be plenty of people out there in this machine. Sounds like Birdy is sitting in one. In cruise with 12 degrees on the prop at 4000 rpm it indicates 65 to 70 knots. However you seem to always hold a bit of right pedal. I have seen trim tabs on many machines and am looking for ideas and wondering if this could be the answer...Deano
Rudder trim tabs
Welcome Deano.[
] Yes, a trim tab is the easiest way. Put the trim tab on the left side of the rudder and bend it out a little until you get it right.The correct and more efficient way with your prop rotation, if I remember correctly the prop rotation of the Rotax 4 bangers, is to increase the offset of the fin. Really, not worth the trouble.O.B. Aussie Paul. [
Hi Russell, yes I am up your way. The pressures to fit the final training of an unhappy asra member between the suspensions that asra have imposed on me is a tough call, but we are hanging in there despite the complications.[
!]Aussie Paul.[8]www.firebirdgyros.com
your not trying to say you are innocent are you paul???was it all a huge big mistake and you have been wrongly accused and are totally innocent..but what are you doing still training an unhappy ASRA member and dare i say taking money from him or her on the presumtion that you are an instructor,sounds a bit like a doctor practising without a licence to me..VERY RISKY..
] givis a call, don't be unsociable MATE[
